My CADMouse keeps pausing as I move around the screen. Is there any chance this is a software issue or is the mouse having a hardware problem?
A regular mouse works fine.
It is just over a year old, I assume there is a warranty.
Thanks.
CADMouse Pausing
Re: CADMouse Pausing
Hello a154610,
please open the Advanced Settings for the CadMouse (from the 3Dconnexion properties) and check what Sensor Polling Rate you have. See if it makes a difference if you change that (to a lower one if possible).
In addition you can disable the lift-off detection and see if this improves the situation.
If you do not find a solution please contact our Technical Support Team.
