I can't customize Wireless CAD Mouse buttons for Revit.
I tried to customize via supplied USB cable with same result.
It seems the customization doesn't work only for Revit - every other app I tried worked fine.
I have Wired CAD Mouse and I can customize the buttons.
Windows 7 Enterpise 64-bit
3DxWare 10.5.10
3DxWinCore 17.5.10.15247
Thank You
Sharas
Can't customize Wireless CAD mouse buttons in Revit
Re: Can't customize Wireless CAD mouse buttons in Revit
Currently Revit lacks full support for 3dconnexion devices, therefore mapping macros to a key is fine, however you cannot natively add, let's say the wall command, to a button. This unfortunately is also true for the 3d mice: eg. Spacenavigator and Spacemouse pro. I just submitted a request to add support to Revit to the Revit ideas forum, which, when having gathered enough votes, will be considered for implementation in future releases of Revit. It apperently is up to Autodesk to add support, not 3dconnexion.
You can cast your vote here.
