Hello Guys,
i'm using for a while now the SpaceMouse Pro Wireless, so far so good.
The problem as the topic says is pretty annoying. It sometimes happen that when I work in Revit the advanced settings just reset, or change to setting I didn't set. It's especially at 3D views in important to keep the settings. Could I do something wrong so it resets?
My solution atm is, to import my settings manuelly when that happens. It's still not the point of a preset Software.
I hope someone can help. Google couldn't.
Revit Settings Resetting Randomly
Re: Revit Settings Resetting Randomly
Hello revitnoob0815,
can you identify a special action that you do once the settings revert?
If the Advanced Settings are reset which application does the driver see? Does it still see Revit?
Are just the Advanced Settings reset to something different or is the button mapping changed as well?
Hello UtaSH,
thanks for the response!
The driver sees the Revit application. And only the Advanced Settings to change. It seems to me that they change to 2D View, while I'm at 3D though.
I have to say it didn't happen now for a while. I keep you updated.
