Spacepilot Pro Turning off itself
Spacepilot pro turns off itself after a couple of hours being idle. I need to unplug it and then to plug it again to USB to turn it on again. I am using latest driver. Been trying also other USB ports, and no other device is having similar issues.
Re: Spacepilot Pro Turning off itself
Hi Boban,
you should check the options of your USB ports management. It might be that the power is turned off after some time?
I get this too sporadically
