Cadmouse Quickzoom side buttons not working
regal180
Post by regal180 » Thu Nov 09, 2017 6:24 am
I'm using Autocad 2017 and I can't get my cadmouse to do quickzoom with the side buttons and the other buttons don't seam to be using commands I've set in the 3dconnexion software. Any suggestions?
Re: Cadmouse Quickzoom side buttons not working
Post by UtaSH » Thu Nov 09, 2017 7:04 am
Hello regal180,
please make sure you install the plugin for AutoCAD. It is included in a default installation of 3DxWare 10.x.x. If this hint doesn't solve your problem I recommend that you contact our Technical Support Team.
mpaz
Post by mpaz » Wed Feb 06, 2019 2:08 pm
Was this problem resolved?
I seem to have the same issue...
Post by UtaSH » Tue Feb 19, 2019 6:52 am
Hello mpaz,
please make sure the addin for AutoCAD was installed with our driver:
  1. In the command bar type "APPLOAD"
  2. This will launch the "Load/Unload Applications" dialog box
  3. Verify that 3dxautocad is loaded
