3Dware 10.5.1 3ds MAX 2017, buttons dont work
mmoraisdois
Post by mmoraisdois »
3DxWare 10.5.1
3DxWinCore 17.5.1.14377
Device: SpaceMouse Wireless Receiver (FW 4.36)
OS: windows 7 64bits
Hello
I install the 3DxWare64_v10-5-1_r2664, everything works but in 3ds MAx 2017 the new assing to buttons don't work.
I try delete ...(User)\AppData\Roaming\3Dconnexion\3DxWare\Cfg\3DsMax.xml to create a new ones, no look.
The file are ok but in max still show the default ring menus.
Re: 3Dware 10.5.1 3ds MAX 2017, buttons dont work
This is a bug. Sorry. It is fixed in the next release. Coming out shortly.
In the meantime, it will work if you use it on the cable.
mmoraisdois
Install new driver 3Dware 10.5.2 and problem solved !
thanks
