Although I am able to assign a mapkey to a particular menu button, none of them work. Has anyone had any luck with this?
Thanks, Bob
Mapkeys and ProE Wildfire?
Hi Peter,
Thanks for the reply.
I'm currently using the 2.6 driver that came with the unit. I did update to both the newer stable version and then the beta but experianced the long delays desrcibed by others in this forum when using ProE.
I simply could not work so I rolled back the driver and the delays became minimal.
As far as the mapkeys I use, they are recorded keystrokes within ProE. Eack mapkey is assigned a single or double keystroke to run the macro.
Note that mapkeys assigned a single keystoke to run do not show up in the ProE Button Mapping editor in 3DX. Also, all of the mapkeys appear in parentheses. I can tell the editor to assign the mapkey but they will not run.
(Edit 1\30) I also noticed that not all of even the two keystroke mapkeys are available in Button Mapping.
Thanks for your help!
Bob
Bob
global and local mapkeys
In my experience only the local mapkeys i.e. the ones stored in the config.pro in the working directory (startup directory) are displayed. The mapkeys in the ..text\config.pro don't appear in the config panel.
