I'm having problems installing either the 3.5 or 3.6.7 software for the Space Explorer on WinXP 64. I downloaded the latest...v3.6.7 and then tried the one that came with it...v3.5... Neither works.
They go through the install process, then freeze. I noticed its launching XSIbatch.exe (32bit). If I kill this process..it seems to un-freeze but it keeps poping up in the task manager. If I keep killing it, it finishes but isn't installed properly and is not recognized in XSI.
I'm running 32 and 64 bit versions of XSI v6.5 and v7.0.
Any ideas?
can not install in WinXP 64
Hi krivel,
We had look at the scenario that you reported and, in our set-up, the installation of the add-in works as expected. We used Windows x64 and a mixed install of 32- and 64-bit XSI.
We also believe we understand what is happening on your system.
To install an XSI plug-in, the installer must call the program XSIbatch.exe. This is an application requirement. XSIbatch is shipped with XSI.
XSIbatch requires access to the network. On Windows XP and later, the operating system may suspend the execution of the program and ask the user if network access is allowed. This is a security feature of Windows. This feature is also standard on third-party firewall software.
We think the OS notice may have gone unnoticed you that XSIbatch is set not to have network access.
Have a look on your firewall software (Windows or third-party) and see if XSIbatch is allowed to access the network.
