Backup and Restore 3DConnexion Profiles
What is the best method for backing up profiles and later restoring them to either the same machine or a different PC? I've tried copying and pasting the "%userprofile%\Application Data\3Dconnexion\3DxWare\profiles" directory, but it doesn't seem to take on a new machine. It ignores the newly pasted profile and creates a different one (or overwrites the copy/pasted one). I made sure to do the copy/pasting with the 3DX driver shut down. It would be great if there were an official procedure. Thanks.
Make sure you have run the driver installation on the second machine.
This is the path the profiles are saved to:
C:\Documents and Settings\your name\Application Data\3Dconnexion\3DxWare\profiles
The files have an extension of .scg
(If you cannot locate the Application data, you will have to enable show hidden files\folders.)
Save a copy of the profiles and
copy them into the same path
First time starting the driver and application switch the profile to the one you copied into the above patch.
I can only speak for the configurations saved by the driver. The plugins also save configurations. Those are saved separately. We can answer those on a case by case basis if needed.
The driver saves your config files in your "Application Data" directory. If you use the APPDATA variable to access this, it will work on any system (Vista included).
Copying all the files from %APPDATA%\3dconnexion\3dxware\profiles on one machine to the other only gets the files there. There is also a registry entry that should be exported and imported (HKCU/software/3dconnexion/3dxware/applications).
These registry entries tell the driver which config file you used last time you ran the application. If you don't export and import that, you will still have the files, but you may have to reselect the user config in the 3DxWare GUI while the application is running.
3Dx Software Development
