Space Pilot and 3dsMax 9 problems
I purchased a Space Pilot a few weeks ago and haven
Hi Dee Stringer,
You have the lasted version of our software for 3ds Max 9.
We do not have reports of our devices causing the sort of display problems as you reported. The problem is not observable on our own systems.
The symptoms that you describe are consistent with a graphic driver issue or an application option for those same drivers.
At this stage, I can only suggest you to upgrade to the latest driver version for you graphic card and check if changing some of the display properties in the application have an influence.
Thanks, ngomes
For the response.
I do have the latest drivers offered from Dell for my system.
I could install the vendor drivers but not without losing some function keys as I understand it. Granted the upgrade may be an acceptable trade off.
Could you perhaps offer some guidelines as to necessary graphics card settings for my type of card or at least the general settings that are being used on your systems that you use to check for symtoms such as mine.
Thanks again for the response. I realize you folks have many issues to persue in a given days time and sometimes someone may fall through the cracks.
Best regards,
Dee
For the response.
Best regards,
Dee
Hi Dee Stringer,
I do not have much to offer, unfortunately. I believe drivers from nVidia have pre-configured settings for well known application (3ds Max being one of them). Try looking on the "Display Properties" panel "advanced" settings.Could you perhaps offer some guidelines as to necessary graphics card settings for my type of card
