Space Navigator not working at all
I installed the space navigator with latest PE drivers
with each software, the device only zoom in-out. PERIOD !
does anyone else had the same issue ?
strange the demos work fine but not the other softs
strange i get the same behaviour in google-earth & blender.
The quick time demo is not working at all
actualy , appart from the provided dummy(but working) cube & airplane demos, NOTHING WORK !!! :$
plz I really need a quick solution for this as I am evaluating this thing and
I need to give my opinion about it for tomorrow, and so far, well I am getting a really bad opinion of the space navigator
It's nice, I love to use it w the airplane demo, so now I only feel FRUSTRATION
edit : After 5 minutes with autocad, only the zoom function is active
all others 6DOFs are gone sudently ???
sheers
Have a great day @
sheers
Have a great day @
as I said before:
Autocad 2OO2 : works, but ends up jittering after a few minutes, need to be reset(not realy a bug?)
Blender : only zoom in out works
Google Earth : only zoom in-out works
QT VR demo : nothing works at all
3DConn demos : all working fine
Im on XP Pro(official one )
drivers : 3.4.2
sheers
Phil
drivers : 3.4.2
sheers
Phil
Hi rompelstilchen,
AutoCAD performance is hardly comparable to true 3D applications. Since you're using a very old version of AutoCAD you may want to try the old plug-in still available on the "archive" section on the software downloads page.Autocad 2OO2 : works, but ends up jittering after a few minutes, need to be reset(not realy a bug?)
These are probably related. The only thing I can suggest is to ensure that the correct configuration is selected on the 3DxWare Control Panel (make sure the application is in the foreground before opening the control panel).Blender : only zoom in out works
Do you have on your system the Apple's QuickTime plug-in for Microsoft Internet Explorer? If not, install it and then do a "repair" of your 3Dconnexion software (from the Add or Remove Programs panel).QT VR demo : nothing works at all
something weird
1 - in the Options menu of the 3Dconn panel, there is a delete configuration
in the poped up window, I see only Autocad
how come Goggle earth and blender are not listed ?
I did an update after all programs are installed but still the same
2 - on the panel itself, there is a drop box wichlists "any application"
I added one for Blender but I don't see why autocad is not listed ???
3 - I have to click on the "3Dconnexion Control Panel" shortcut at reboot
is it not automaticaly set at startup ?
I keep on playing with it until I'll get it to work.damn thing !
edit : got it to work with google earth, dont know how ???
now there is another "any application-[my user name]" listed in the delete conf popup window
why is Blender not listed ? I dloaded 20070311.zip , is this not the right one ?
sheers
sheers
Regarding Blender bugs, I have a thread going here:
viewtopic.php?t=1521
You did grab the NDOF release of Blender, right? Some tips just to get you going:
- assign "Button1" to the left button on the 3DNavigator
- assign "Button2" to the right
- Crank up the overall acceleration to two or three stops from the top (in the driver)
- Download the NDOF build (smf_1-1-4_inst.tar worked well for me) and run that version of Blender. If you check the console messages you should see that the 3DX device was recognized.
- When you get into Blender, look below the view screen, there's a label that says "6dof" and the mode. You can either be in Turntable, Fly or Edit modes, so make sure you're in Fly (Turntable works backwards at the moment).
Finally, check the thread above and see if you have any of those issues, that will help!
The first thing I ever made in Blender was a cube.
http://3dpipeline.net
I can only assign to keys and othr stuffs, not to mouse clicksavaktar wrote: - assign "Button1" to the left button on the 3DNavigator
I use XPavaktar wrote: smf_1-1-4_inst.tar
turntable or trackball do the same for me (???)
Last edited by rompelstilchen on Sun Oct 07, 2007 1:31 am, edited 1 time in total.
Ok, I found the bug, it was in my head, now I got the right blender NDOF
working ok but :
- only blender invert all axes
- it doesn't do anything in camera view/fly mode
- turntable,tackball, and around selection buttons have no efect,
how do we switch from turnable to trackball? I wnt to navigate outside of selected object center
- after a while, forwrd, backwrd motion don't work anymore ??
any suggestions ?
working ok but :
any suggestions ?
Hi rompelstilchen,
The 3DxWare Control Panel loads the configuration for the application that is on the foreground. In other words, the "configuration for" pull-down menu (combo box) will only list the valid configurations for the application that has the foreground and supports a 3D mouse (which includes the "any application" configuration).
If you cannot see the 3DxWare icon on the system tray, that's because -- most likely than not -- you unchecked the option to have the driver automatically start when Windows launches. You can copy the "Start Driver" shortcut to the "Startup" folder or, perhaps it is safer, you can re-install the software.
