Random NX crash
drkieffer
Random NX crash
Post by drkieffer » Thu Nov 05, 2015 1:31 pm
Running NX 9, SpaceExplorer and a CadMouse, with the 10.2.9 3Dconnexion driver. SpaceExplorer firmware ver. 3.18
Another user has the 10.2.6 driver version. and no CadMouse.
Other users, with similar workstations without the CadMouse are having the same random crash. You will be zoom/pan/rotating with the SpaceExplorer and *poof* NX has stopped working and it departs. No pattern that we have noticed.
IT has looked at the event viewer, with no insight. We have gone thru the workstations making sure the video driver is the latest certified by Siemens.
Thoughts?
-Dave
Siemens NX9 with Teamcenter 10
SpaceExplorer and CADmouse
Re: Random NX crash
Post by UtaSH » Mon Nov 09, 2015 7:15 am
Hi Dave,
have you tried if the crash happens as well if the driver for the 3D mouse (and CadMouse) is not installed? I know it is difficult to work without 3D mouse, but you should give it a try.
drkieffer
Re: Random NX crash
Post by drkieffer » Tue Nov 10, 2015 9:01 am
I may give that a try...I'm not sure which will cause a larger productivity loss, random crashes, or now 3D motion controller :)
-Dave
Re: Random NX crash
Post by jwick » Wed Nov 11, 2015 3:01 am
If NX crashes, Siemens should be able to help. Certainly they collect information when their application crashes. If it is related to the 3D device, they will know and will contact us.
drkieffer
Re: Random NX crash
Post by drkieffer » Wed Nov 11, 2015 5:20 am
jwick wrote:If NX crashes, Siemens should be able to help. Certainly they collect information when their application crashes. If it is related to the 3D device, they will know and will contact us.
I grabbed all the logs for them awhile back, IR 7536666, so I switched to the latest certified video driver. I was good for about a month, then 3 of us had crashes in one day, which led me here, to see if anyone else noticed behavior like this.
That said, I am prepared to grab the syslogs again for Siemens, but of course now that I'm ready, NX won't do it...Murphy and that law of his.
-Dave
drkieffer
Re: Random NX crash
Post by drkieffer » Mon Dec 14, 2015 8:20 am
@jwick
NX continues to crash randomly for myself, and another user. Speaking only for myself, it always seems to be when moving the Space Explorer, this morning I was only rotating my model, when NX stopped working. I have supplied log files to Siemens, and they have not found anything in the logs, the crash is so fast, nothing of importance is being written. I'm very close to having an "Office Space" type event with this SpaceExplorer :twisted:
I've swapped to a SpaceNavigator, hoping to narrow this down.
-Dave
Re: Random NX crash
Post by jwick » Mon Dec 14, 2015 8:29 am
That sounds strange that they wouldn't have a minidump.
Can you put us in contact with the person who was handling the support request at Siemens?
We may be able to walk that back to the developers.
In the meantime, if you haven't already tried, you can uninstall our add-in for NX to see if that makes any difference. I don't think it is used much for the SE. What's left is completely enclosed inside NX.
drkieffer
Re: Random NX crash
Post by drkieffer » Mon Dec 14, 2015 8:52 am
OK, SpaceNavigator did NOT help, NX crashed again. I'm starting to think this is OS, or hardware related, 3 users have all had random NX crashes. The first crash you get a message, "NX has stopped working" after that, just *poof* gone.
-Dave
drkieffer
Re: Random NX crash
Post by drkieffer » Mon Dec 14, 2015 9:34 am
jwick wrote:That sounds strange that they wouldn't have a minidump.
Email sent with the Siemens rep contact info, and IR number.
What do I have to do to remove the 3Dconnexion plug-in?
-Dave
Re: Random NX crash
Post by jwick » Mon Dec 14, 2015 10:01 am
To remove the NX plugin, you should be able to run the 3DxWare installer and unselect the NX plugin.
There may be other ways, like something in NX, but I'm not familiar with that.
drkieffer
Re: Random NX crash
Post by drkieffer » Mon Dec 14, 2015 10:30 am
jwick wrote:To remove the NX plugin, you should be able to run the 3DxWare installer and unselect the NX plugin.
Done. Also installed the 10.3.0 driver too.
-Dave
drkieffer
Re: Random NX crash
Post by drkieffer » Mon Dec 14, 2015 11:28 am
Crashed again. This time I had Process Manager logging, so I'm hoping our IT people might be able to gleen something from it.
-Dave
drkieffer
Re: Random NX crash
Post by drkieffer » Thu Jan 07, 2016 5:30 am
I believe we have finally solved it. It seems the Nvidia driver was the culprit, even though it was "certified" by siemens. I have gone to the newest driver, which I am told is also "certified", but not yet listed on the certified drivers list. Since then, no crashes in almost 2 weeks. New driver is being deployed to all users.
-Dave
stauwer
Re: Random NX crash
Post by stauwer » Thu Jan 07, 2016 6:45 am
Hi drkieffer,
With what graphics card you had the problem? And which driver version do you use?
drkieffer
Re: Random NX crash
Post by drkieffer » Thu Jan 07, 2016 6:51 am
nvidia K4200, K4000, and M5000, which are all Quadro cards.
Driver version 354.56 is what the solution was.
-Dave
