Hi
In SolidWorks I
Button for set center point / rotation center in Inventor
Hi KP
There is a function in Inventor called "Rotate F4" which you can map on a key from your device. Using this function you will be able to set a rotation point.
You can map that function using the "Button Mapping Editor", by selecting the category "View" and dragging the "Rotate 4F" to a key of your device.
agoenczi
Hi KP
Unfortunately different applications means different conventions, different tools. In this case Inventor has a very different approach from the one used in SolidWorks: the rotation center will be always the geometrical center of the screen and the object will be moved according this convention.
agoenczi
