Maya 2014 mapping buttons
vedus
Post by vedus »
i Have installed the maya and the plugins from 3dxware..
All is ok no errors and the spacepilot pro working in all axes and default buttons!!
I remember in maya 2013 was menu to change the defaults buttons and customise the spacepilot pro inside in maya with other working tools.
the menu in maya have only the default "open 3dconnexion properties and when i clicked i go to standard external default mapping.
How i will map new tools inside maya and NO the defaults from the external?
Re: Maya 2014 mapping buttons
Post by Barbara »
Hello vedus -
In the Release 10.0.14 driver the add-in button mapping is integrated into the driver. When you choose 'Application command' in the button mapping drop-down the Maya commands are available. The separate editor inside Maya is no longer needed - the 3Dconnexion Properties button mapping now has all of those commands. This driver also has the new radial menus that allow 4 commands to be mapped to each radial menu.
