SpaceExplorer Not Working in Sketchup Using Mountain Lion 10
Re: SpaceExplorer Not Working in Sketchup Using Mountain Lio
The deletion of "com.3dconnexion.mappings.plist" did work to re-enable the SE initially, but did not survive a reboot.
I did add SketchUp accordingly again to be able to use the SpaceNavigator after a reboot, but there is no com.3dconnexion.mappings.plist file in the indicated folder (only others, like com.3dconnexion.macros.plist).crobl wrote: (For those of you that already added SketchUp according to my hint given earlier in this thread, please:
- remove (backup first!) your ~/Library/Preferences/com.3dconnexion.mappings.plist)
If the SpaceNavigator only stopped working after reboots it wouldn't be so bad, but whenever I use the Shape Bender plugin in SketchUp it stops working immediately after bending the shape. And this is plain annoying.
I'm using SketchUp free 8.0.16845, 3dconnexion driver 1.7.2, firmware 4.31, OS X 10.8.3.
I'm new to this forum.I just wondered if any one knows what is the latest version of Mac OS that will run Vectorworks 2009? My late 2011 mbp just died and I rather not have to spend 2k plus on a new version of Vectorworks that will run on a new Mac so have decided to buy a newer second hand mbp but need to be sure vectorworks will run on the OS first. Any help would be much appreciated.
