- I can control the mouse cursor position and scroll the CADMouse Wireless' middle wheel but left and right clicks don't seem to register
- I can control the mouse cursor with the SpaceMouse, click with the left and right buttons ... but the device doesn't show in Settings | 3Dconnexion | Tools (see screenshots below).
- If I try to launch the Trainer app from the 3Dconnexion Home app that launches on startup, Trainer seems to start briefly (show in the menu bar) and then quit.
Spacemouse Wireless: Device Not Found
I've just purchased the SpaceMouse Wireless Kit for use with my MacBook Pro running Catalina 10.15.3. I have installed the latest (10.6.5) version of 3DxWare and rebooted (twice) but I'm seeing strange behaviour.
Re: Spacemouse Wireless: Device Not Found
Well, I found my issue. This note in relation to Mojave still applies to Catalina: https://www.3dconnexion.com/nc/service/ ... ojave.html.
After allowing loading of the kernel extension, I can now see both the SpaceMouse and the CADMouse in the Device pane.
Unfortunately, when I run Fusion 360 (the application that I specifically wanted to use with the SpaceMouse), the cpu usage goes straight to 100%. And if I actually try to use the application, my laptop fan fires up and it's more like 160%. And half the time I start Fusion, the SpaceMouse doesn't function. So I uninstalled the kernel extension and immediately saw my idling Fusion cpu usage go back down to <10%.
This is really unfortunate. I was so looking forward to my SpaceMouse
