Spacemouse Enterprise Inverted in Maya
JoshuaBell
Post by JoshuaBell »
I am using Maya 2018. I specifically brought this to use with my Maya in my degree program. In the 3dconnexion software everything moves correctly using the trainer and puzzle. When I open Maya 2018 and use the space mouse everything is inverted and moving in the opposite direction. When I move up the models moves down. When I push down the model moves up. When I rotate to the left the models rotates to the right. Everything seems to be inverted when using Maya.
When checking the 3dconnexion software settings under Maya in the dropdown menu everything looks correct. I have no idea why everything is inverted.
Re: Spacemouse Enterprise Inverted in Maya
Hi JoshuaBell,
try if setting the configuration back to default helps. Select Maya in the top of the 3Dconnexion properties window and then click to "Use Defaults" at the bottom. If this does not help switch to the next tab "Axes" and do the same.
Let me know what you find out.
