SN Error in Maya 2008
jfa
Post by jfa »
When using the Space Navigator (Standard Edition, driver v1.5.0) In Maya 2008 on OS X (10.5.3) with a tool being active (e.g. Split Polygon Tool, Extrude Tool, Append to Polygon Tool etc.) I get the following error message in the Script Editor:
// Error: No valid objects supplied to 'xform' command.
This will be repeated every time I touch the SN
dggraphics
New driver
Post by dggraphics »
Have you tried the new driver 1.5.1 ?
Does this still happen or has it been corrected?
jfa
driver v1.5.1 doesn't solve the problem
Post by jfa »
I've installed the latest driver (v1.5.1), but unfortunately, the problem persists.
flomotan
Post by flomotan »
We were able to reproduce the issue and we've filled a report with Autodesk about it. We're now looking for ways to prevent the message from coming up while Autodesk reviews the issue.
Thanks for reporting this.
jfa
same error in 1.5.2
Post by jfa »
Unfortunately, the error still occurs with the latest driver v1.5.2.
So what is the current state in resolving this issue?
flomotan
Post by flomotan »
A work-around is in process and will be part of the next Mac driver release which should be available later next week.
