What app would you like to see supported on Mac OS X?
What application would you love to see supported on Mac OS X?
Poll ended at Sat May 10, 2008 1:04 pm
Motion
1
5%
Final Cut
2
9%
iMovie
0
No votes
Cinema4D
13
59%
zBrush
1
5%
Logic Express/Pro
1
5%
After Effects
4
18%
InDesign
0
No votes
Apple Shake
0
No votes
Apple Shake
0
No votes
Apple Shake
0
No votes
Apple Shake
0
No votes
Total votes: 22
imaks
Re: Cant this device scroll system wide?
Post by imaks » Wed Nov 26, 2008 7:56 am
joelcarlton wrote:Aperture would be great.
Why cant these devices be implemented into the system, well, system wide?
Why cant there be a setting in the system prefs. to allow tilt back and forward to be scroll and down and up to be zoom? Devices like wacom tablets will work anywhere on the system because the admin controls let you set up tones of key command and gestures. Why can I customize this to have press down be command-shif-+ and up be command-shift-_ ???
I bought this instead of the griffen powermate but now im thinking this isn't going to let me do simple things like scroll.
Maybe im just confused.
Any suggestions?
I was making the same question.
Why?
marty
Unity3D Support
Post by marty » Wed Nov 26, 2008 1:51 pm
I would like to see support added for Unity!
http://unity3d.com
Windy
Post by Windy » Sun Nov 30, 2008 7:35 am
The current list of support applications is quite impressive already = )
adrianoc
Post by adrianoc » Mon Dec 15, 2008 10:42 pm
Better support for Mathematica: only two of the 6 degrees of movement work now: up and sideways translations, which work as rotations (!?!)
David.Mac
Post by David.Mac » Tue Jan 13, 2009 3:10 am
Photoshop CS4. I bought for CS3 - It worked beautifully. If you supported the earlier two CS releases why not this one? Lets have it back please.
David Mac
flomotan
Post by flomotan » Wed Jan 14, 2009 4:14 pm
The latest driver, v1.5.6, has a plug-in for PS CS4. There is a redraw issue when you're stopping navigation in 3D. We've notified Adobe of this and hopefully it will be fixed in their first patch.
2D should work fine.
David.Mac
Post by David.Mac » Thu Jan 15, 2009 2:28 am
OK ... a bit more detail
Power Pro 2 x 2.8 Quad-Core Intel. 8.0 GB RAM
2 x NVIDIA GeForce Video cards full Open GL support
Standard two button Navigator.
3D Connexion Control Panel shows 1 3Dconnexion devices found. Driver V1.5.6, Firmware revision 3.18
The control panel drop down shows CS4 as an option for setup.
In Sketchup Pro 6 the Navigator works perfectly so there seems no reason to suppose that there is a general physical connection problem or driver problem.
In CS4 X the navigator does nothing! Neither in 2D or 3D.
All CS's own internal navigation functions work fine with pen or mouse - smooth and fast.
There is one issue that could be implicated. In the past there were difficulties with non English keyboards (particularly with brush size) as the navigator used keyboard shortcuts. No idea if this could still be an issue here but as far as I know the navigation aspect of the controller is entirely independent of keyboard.
The two programmed buttons do work. Navigation does not. The odd thing is that it doesn't jump, or limp, or struggle, or show any other signs of glitches ...... it simply does absolutely nothing at all.
Frustrating ........ :cry:
David Mac
David.Mac
Post by David.Mac » Thu Jan 15, 2009 3:04 am
OK ignore this last post. The problem has been solved in another thread ... well partially anyway ......
I shall leave this post alone and continue only in the other "Uhh, Photoshop CS4 extended"
Sorry about this. I didn't mean to double post, what started as two threads got intertwined. :oops:
David Mac
David Mac
Lucho23
Mac Apps
Post by Lucho23 » Sun Feb 01, 2009 10:12 pm
I want full support for Rhino 3d for Mac OS X Leopard, I have been using the beta for one year but is not support for any buttons in the control panel for the space exlorer and the space navigator
Luis
ianjw
Photoshop CS4
Post by ianjw » Fri Feb 06, 2009 6:36 pm
PLEASE PLEASE PLEASE
LarryS
modo by luxology.com
Post by LarryS » Fri Feb 13, 2009 6:58 pm
Very powerful and fun 3D program. Could really use the support of your devices.
Yops
support software for mac
Post by Yops » Sun Feb 15, 2009 9:33 am
I'd like to see the support for Maxwell studio (next limit), final cut, logic Express, imovie and quicktime and Archicad 2D
thank you :)
cjcstl
NX6
Post by cjcstl » Mon Feb 16, 2009 10:57 am
Unigraphics NX6
transco
Post by transco » Wed Feb 25, 2009 8:52 am
I don't seem to be able to vote directly, so please add me to the 'Final Cut' tally.
downhomebythesea
Post by downhomebythesea » Tue Mar 03, 2009 2:05 pm
Final Cut, Motion, After Effects.
