CadMouse and Fusion360 Tips&Tricks
YesPapa
Post by YesPapa » Fri Mar 25, 2016 2:17 am
Does somebody set the CadMouse for Fusion 360 software?
Thank you.
Re: CadMouse and Fusion360 Tips&Tricks
Post by UtaSH » Wed Mar 30, 2016 5:17 am
Hello YesPapa,
what exactly do you want to set?
YesPapa
Post by YesPapa » Sat Apr 02, 2016 3:06 am
I want to set all the buttons. When I use the mouse with the software some buttons are not actives.
Radial Menus :
I want to match with front, top, left, right views
Middle Button :
I want to match with orbit when press it and another keyboard
etc.
I want to know how to do it.
Thank you.
Post by UtaSH » Tue Apr 05, 2016 8:52 am
Hi YesPapa,
you can find some of the defined views in the list of the button mappings. Open the driver window (3Dconnexion properties) and open the "Buttons" window. Open the list with the functions next to the button that you want to map. Type the command that you are looking for. For example "Top" for Top View. The command will be listed and you can select it.
See as well our help file for explanation about Button Mapping.
There is a predefined Radial Menu "RM Views" which has some of the views already mapped. If you do not see the correct names of the views that is because Fusion 360 doesn't provide them to the driver. This has to be fixed by Autodesk. Please address this issue with the Support Team of Autodesk to let them know that users need a fix.
YesPapa
Post by YesPapa » Tue Apr 05, 2016 3:10 pm
Thank you. I have a look at it.
