Blender 2.46 amd64
RoboticGolem
Blender 2.46 amd64
Post by RoboticGolem » Sat Aug 09, 2008 11:08 pm
I've poked around, and found an amd64 plugin for blender, but it doesnt seem to work.
Searching here, I've found that the plugin will work if I switch to an older version of blender.
I do understand that this software is alpha, but is there any way to have you release the amd64 version of the plugin for blender? Or at least for blender 2.46?
Does anyone here have a working plugin for 64bit linux and blender 2.46?
CasperN
Post by CasperN » Wed Aug 20, 2008 4:42 pm
where can I find the 64bit plugin?
adavis
Post by adavis » Sat Aug 23, 2008 8:35 am
I dredged one up, but it doesn't seem to work.
I have the device setup properly, the xcube demo works perfectly. I have performed the button assignments.
When I start blender, I get:
Magellan App Window: 0x3e00002
Magellan Motion Event ID=535
Magellan Command Event ID=538
Magellan Root Window: 0x13b
Magellan Driver Window: 0x3800163
Magellan Driver Window Name: Magellan Window
But the device does not control blender at all. No axis seems responsive.
I see that others have posted similar issues, but the resolution always appears murky. Is there a correct 64bit plugin that I should be using? Are there any other hoops that I need to jump through?
CasperN
Post by CasperN » Sat Aug 23, 2008 8:46 am
try one of this plugins http://www.root42.de/blender/
take the 3DxNdofBlender.plug and put it in the blender 2.46 plugin map
adavis
Post by adavis » Sat Aug 23, 2008 6:23 pm
That did it!
