SpacePilot buttons send wrong cmd (keyboard config?)
PatBomb
Post by PatBomb » Mon Apr 14, 2008 2:58 pm
I installed a SpacePilot on HP-UX and all works fine on my computer.
But when I install the component on a Danish computer I got the following problem with command buttons (circled in blue numbers buttons, just below the LCD).
For exemple:
In CatiaV5
shading command send (like a keybord)
c:shading (shd)
But on a danish computer it send:
c;shading )shd=
My config for keyboard (/etc/kbdlang)
PS2_DIN_US_English
On a danish computer:
USB_PS2_DIN_Danish_Euro
crobl
Post by crobl » Tue Apr 15, 2008 5:49 am
Hi PatBomb,
I'm sorry to say, that this is kind of a known issue. Unfortunately we cannot test every language environment and keyboard layout, so we decided just to provide configurations for english keyboard layout and language environment. If you'd like to have the configurations for a danish environment and keyboard layout you have to modify the provided configurations to fit this layout.
For example create a custom configuration and enter the shading command as it should be...
c:shading (shd)
... and save the configuration.
Open this configuration in a text editor and search for the keyword BUTTON_CHARACTERS. Have as look at the shading command sequence you typed. Now edit the default configuration's macros to match these key codes.
If this doesn't work for you, please let me know! You can also write a private message, if you like.
Regards,
Christian Robl
