3DxWare 1.2.0 isn't displayed correctly
Moses
Post by Moses » Sun Dec 02, 2007 9:01 am
Hi
After I started the daemon with "sudo /etc/3DxWare/daemon/3dxsrv -d usb"
a Window opens, obviously something for configuration.... but it looks very mixed up. How can I fix this? Or could you please fix this in your next release?
Screenshot:
thank you for your help :)
Moses
crobl
Post by crobl » Mon Dec 03, 2007 7:04 am
Hi Moses,
what the ... :shock: Oh dear! I haven't seen our GUI distorted, least of all like this.
What desktop and/or window manger are you using?
What Linux distribution and kernel version do you use?
Which version of 3DxWareUNIX are you using (3dxsrv -v)?
What Motif libraries have you installed and which version are they?
Regards,
Christian Robl
Moses
Post by Moses » Mon Dec 03, 2007 1:32 pm
Desktop: Gnome + Compiz Fusion
Distribution: Ubuntu 7.10
Kernel: ahhhhhm.... the newest? i think it ends with .xx-22
3DxWareUNIX = V1.2.0, ID 2770
Motif: ok just installed all libs I found with aptitude.... now it works ;) thank you :D
Great Support! Thank you!
PS: Salute to my friends, who gave me this great device to my birthday: Now it WORKS! Thank you guys! :lol:
ellson
Post by ellson » Sun May 04, 2008 7:42 am
I see the same problem on Fedora 8 and 9, x86_64 boxes.
I have lesstif installed.
I guess Motif is proprietary? " yum list *motif* " produces no hits.
Why does a driver open a window at all? The driver seems to work inspite
of the window being borked and useless (xcube works).
Shouldn't this be done by a separate utility program?
crobl
Post by crobl » Tue May 06, 2008 10:11 am
Hi ellson,
please uninstall lesstif and install recent OpenMotif packages. This should fix your problems. I've seen that (some versions of) lesstif has a/some bug/s that result in a buggy GUI.
Regarding Motif: It is not really proprietary. Well, the original Motif kind of is/was, but the open source developments OpenMotif and lesstif aren't. Its a commonly used UI toolkit on UNIX and Linux (on the latter one it gets more and more replaced by more recent UI toolkits).
I wonder why your yum-command doesn't produce any output. It should at least print out lesstif. What if you widen the search criteria and just search for *otif*? or what does rpm tell?
rpm -qa | grep otif
Anyway, please let me know if switching to OpenMotif helps solving your problem!
Regards,
Christian
