I've read thru some posts here to try and solve my problem, but cannot for some reason. This is a AIX 5.3 machine. Driver starts up when "root" is logged in - but not "user".
Added the below line in /etc/inittab
3d:234:respawn:/etc/3DxWare/daemon/3dxsrv -d usb -debug -E /dev/null >/dev/null 2>&1
Below is the output of the log file
[2007-09-27 09:06:10] 3dxsrv.c,651: displayname = $DISPLAY set to :0
[2007-09-27 09:06:11] auth.c :: authGetUser(), FOUND: user = catusr, id = dt, line = lft0, pid = 86090, host = , type = 7
[2007-09-27 09:06:11] auth.c :: authGetUser(), FOUND: user home = "/home/catusr"
[2007-09-27 09:06:11] 3dxsrv.c :: startupInittab(), authGetUser(), user=catusr
THANKS FOR YOUR HELP !!!!
Startup Problems
Hello Andy,
to get a better understanding of what is going on please let me ask some questions first:
Which version of 3dxsrv are you using ("3dxsrv -v")?
What is the maintenance- or technologylevel of your AIX 5.3 ("oslevel -s" and "oslevel -r")?
Do you have any special setups (access permissions) that may prevent the driver from starting?
Which device are you using? Do the device LEDs (if present) light up?
Regards,
Christian Robl
Regards,
Christian Robl
Hi Andy,
thank you for the information on your AIX. Actually our driver should run without problems.
One idea though:
Can you please try to start the driver with -d /dev/mouse1 (or what the device node for your SpaceMouse Plus is) instead of -d usb.
Please let me know if this a possible solution for your issue.
Regards,
Christian
One idea though:
Regards,
Christian
