Xinput driver for Spaceball 5000 on Linux?
Adrian Majesk
Post by Adrian Majesk »
Is there an Xinput driver available for the Spaceball 5000 on Linux? I am trying to use the Spaceball to remotely control a Linux workstation via XDMCP, running through Hummingbird Exceed (http://connectivity.hummingbird.com/pro ... index.html) on a Windows computer. Hummingbird Exceed supports the Spaceball 5000 but for XDMCP, uses the Xinput Extension to send instructions to the remote machine. I've contacted Hummingbird technical support, and apparently I need to install an Xinput based driver on the Linux machine in order to use the Spaceball over XDMCP. I'd appreciate any help.
Adrian
crobl
Post by crobl »
Hi Adrian,
unfortunately our driver for Unix and Linux does not support the XInput Extension.
Maybe a modification to the xserver config described here could serve you as base for a workaround?
Best regards,
Christian Robl
