Spaceball 4000 with Windows XP x64
robertha
Post by robertha »
Hello
I am trying to get the Spaceball 4000 to work with my application written in C++ (Visual Studio 2005). I am connecting it over a serial cable. I use Driver v2.8.2 and the 64-bit SDK 2.1.1.
My init code looks like this:
SiOpenData open_data;
sint32_t err = SiInitialize();
if ( err != SPW_NO_ERROR )
	VTLOG("   SiInitialize failed: %s.\n", SpwErrorString(SpwErrorVal));
	SiTerminate();
	return false;
//Win32 hwnd
WNDCLASSEX  wndclass;        /* our own instance of the window class */
static HINSTANCE   hInst;        /* handle to our instance */
memset(&wndclass,0,sizeof(wndclass));
hInst = (HINSTANCE)GetModuleHandle(NULL);             /* init handle */
wndclass.cbSize        = sizeof(WNDCLASSEX);
wndclass.style		   = CS_HREDRAW | CS_VREDRAW;
wndclass.lpfnWndProc   = (WNDPROC)Device3DxImp::HandleNTEvent ;
wndclass.cbClsExtra    = 8;
wndclass.cbWndExtra    = 0;
wndclass.hInstance     = hInst;
wndclass.hIcon         = LoadIcon(NULL, IDI_APPLICATION);
wndclass.hCursor	   = LoadCursor(NULL,  IDC_ARROW );
wndclass.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
wndclass.lpszMenuName  = NULL;
wndclass.lpszClassName = (LPCWSTR)"SpaceWare";
wndclass.hIconSm       = LoadIcon(NULL, IDI_APPLICATION);
// Register the display windows class to be used for subsequent calls to
// CreateWindow.
if(!RegisterClassEx(&wndclass))
	VTLOG("   Window for 3Dx device could not be registred.\n");
	SiTerminate();
	return false;
// Create a window to use for getting messages from the SpaceWare device.
HWND hwnd;
hwnd = CreateWindowEx(
	0,
	(LPCWSTR)"SpaceWare",
	(LPCWSTR)"SpaceWareSensor",
	WS_OVERLAPPEDWINDOW,
	CW_USEDEFAULT, CW_USEDEFAULT,
	HWND_MESSAGE,
	NULL,
	hInst,
	NULL);
if( hwnd == NULL )
	VTLOG("   Window for 3Dx device could not be created.\n");
	SiTerminate();
	return false;
// init Window platform specific data for a call to SiOpen
SiOpenWinInit( &open_data, hwnd );
if ( SpwErrorVal != SPW_NO_ERROR )
	VTLOG("   SiOpenWinInit failed: %s.\n", SpwErrorString(SpwErrorVal));
	SiTerminate();
	return false;
// open the SpaceWare device
if ((_3DxHdl = SiOpen ("GeoViz", SI_ANY_DEVICE, SI_NO_MASK, SI_EVENT, &open_data)) == SI_NO_HANDLE)
	VTLOG("   Could not open a 3DxWare device, %s.\n", SpwErrorString(SpwErrorVal));
	SiTerminate();
	return false;
VTLOG("   3Dx device found and initialized.\n");
It gets all OK until I call SiOpen at the end, then it fails with:
Internal 3DxWare error
What am I doing wrong?
Does the new Driver SDK support the Spaceball 4000 serial?
Thanks for your help
Robert
Hi Robert,
The code seems fine. Does the driver get started by SiInitialize?
Does the device beep?
Turn on logging in the GUI. The 3dxware.log file should list your connection attempt.
3Dx Software Development
