I developed a Labview Interface for the Space Navigator, at the end I realized that Labview got motionData although I disconnected the USB cable for serveral times.
At first I thought this might be a Labview Problem, but it is also in your Demo Programm. New Data are shown very quickly until I disconnect the Device, than it shows 2-3 seconds old(?) data.
I need to get TX,TY... =0 directly when the USB Cable is disconnected. Is this possible? What is the problem that I got motionData after disconnecting the device for many seconds?
best regards, zess
MotionData after disconnecting the SpaceNavigator?
I think I´ve got the C interface, which I downloaded from your website with the Demo 3Dx Test32, I changed the C Code a little bit and created a DLL with Visual Studio, which I use in Laview.
I`ve signed up for the webinar tomorrow... I know, that you can use the COM Interface directly in Labview 8.2.
Is the C Interface the problem?
zess
zess
Hi zess,
No, the C interface should not be a problem. It is fully supported by 3Dconnexion but we do ask developers to first consider the (newer) COM interface.
The COM interface is installed with the driver since release 3.1. You can find the documentation on the SDK page.
ah okay, didn`t see your post...ngomes wrote:Hi zess,
i will download the new one and try again...
Well, we certainly have never had anyone try doing that before. Yes, it does keep sending data for a second or two before the disconnection gets noticed. Fixing this would require changes to the driver.
Is there a particular reason why you are yanking the cord out of the machine? Perhaps there is a better way of resolving your issue.
Jim
3Dx Software Development
Jim
hello jim,
I tried it, because this may be an error in the application area. I thought abouth something like "stumbling over the cable"... any uncontrollable second could be fatal. At the moment I solved the problem with a switch which had to be pressed in order to get data from the space navigator, this switch is connected to the LTP port.
Is there an easy way to change the driver? Is there a cache? What has to be done? how does it work?
zess
zess
