SiOpen return NULL
malfatti
SiOpen return NULL
Post by malfatti »
Hi all!
I´am writing you expecting some help because I no have ideia how to solve my problem.
I have two codes, the first is the 3DxTest that comes with 3DConnecion SDK. This code works rigth. The problem is, that in my opengl graphics application, that I use the same code that 3DTests, the function SiOpen returns NULL;
Here is my codes:
bool CVRMouse3D::Init(HWND hWndMain)
	//variaveis locais
	int res;
	SiOpenData oData;
	//Inicialização do dispositivo
	if (SiInitialize() == SPW_DLL_LOAD_ERROR)
		return false;
	SiOpenWinInit(&oData, hWndMain);
	SiSetUiMode(NULL, SI_UI_ALL_CONTROLS);
	devHdl = SiOpen ("DefaultApp", SI_ANY_DEVICE, SI_NO_MASK,  SI_EVENT, &oData);
	return  devHdl ? true : false;
I have tested the hwndmain reference and its a valid pointer. Some ideia?
Thank you!
malfatti
Re: SiOpen return NULL
Post by malfatti »
Here is the code that I use to create my Window:
void CVRWindow::Show()
	WNDCLASSEX	windowClass;//Window class
	DWORD		dwExStyle;//Window extended style
	DWORD		dwStyle;//Window style
	RECT		windowRect;//Rect used to store the window dimensions
	/*Init window rect values*/
	windowRect.left = (long) 0;
	windowRect.right = lWindowWidth;
	windowRect.top = (long) 0;
	windowRect.bottom = lWindowHeight;
	/*Fill out the window class structure*/
	windowClass.cbSize = sizeof(WNDCLASSEX);
	windowClass.style = CS_HREDRAW | CS_VREDRAW;
	windowClass.lpfnWndProc = MainWindowProc;
	windowClass.cbClsExtra = 0;
	windowClass.cbWndExtra = 0;
	windowClass.hInstance = hInstance;
	windowClass.hIcon = LoadIcon(NULL, IDI_APPLICATION);//Default icon
	windowClass.hCursor = LoadCursor(NULL, IDC_ARROW);//Default arrow
	windowClass.hbrBackground = NULL;//Don´t need background
	windowClass.lpszMenuName = NULL;//No Menu
	windowClass.lpszClassName = "DefaultApp";//Window class name
	windowClass.hIconSm = LoadIcon(NULL, IDI_WINLOGO);//Windows logo small
	//Register the window class
	if (!RegisterClassEx(&windowClass))
		return;
	/*Testing the fullScreen flag*/
	if (bFullScreen)
		DEVMODE dmScreenSettings;//Device mode
		memset(&dmScreenSettings, 0, sizeof(dmScreenSettings));//Inits the device
		dmScreenSettings.dmSize = sizeof(dmScreenSettings);//configure the size
		dmScreenSettings.dmPelsWidth = lWindowWidth;//Screen width
		dmScreenSettings.dmPelsHeight = lWindowHeight;//Screen height
		dmScreenSettings.dmBitsPerPel = uiWindowDepth;//bits per pixel
		dmScreenSettings.dmFields = DM_BITSPERPEL | DM_PELSWIDTH | DM_PELSHEIGHT;//Config the pixels type
		/*Test if the screen change was sucessful*/
		if (ChangeDisplaySettings(&dmScreenSettings, CDS_FULLSCREEN) != DISP_CHANGE_SUCCESSFUL)
			//Setting display mode failed, switch to windowed
			MessageBox(NULL, "Configuração de vídeo não disponível",NULL, MB_OK);//Show the error message
			bFullScreen = false;//Change resolution back
	//Verify if we are still in fullscreen mode
	if (bFullScreen)
		dwExStyle = WS_EX_APPWINDOW;
		dwStyle = WS_POPUP;
		ShowCursor(FALSE);
	else
		dwExStyle = WS_EX_APPWINDOW | WS_EX_WINDOWEDGE;
		dwStyle = WS_CAPTION |WS_SYSMENU;
	/*****Adjust window to true requested size******/
	AdjustWindowRectEx(&windowRect,dwStyle, FALSE, dwExStyle);
	/******Class registered, so now we will create our window*****/
	hwnd = CreateWindowEx(NULL,
						"DefaultApp",
						cTitle,
						dwStyle | WS_CLIPCHILDREN | WS_CLIPSIBLINGS,
						xPos, yPos,
						windowRect.right - windowRect.left,
						windowRect.bottom - windowRect.top,
						NULL,
						NULL,
						hInstance,
						NULL);
	/******Show the window*****/
	ShowWindow(hwnd,SW_SHOW);
	UpdateWindow ( hwnd );
malfatti
Post by malfatti »
Trying to solve this problem I paste the code of my project into that visual studio project that comes with SDK and works! :D
So my conclusion is that in my own project exist some missing configuration parameter!
I will to comare both projects to discover what is missing.
regargs.
