Binding Modifier+Key to rotation axis
Josh
Post by Josh » Thu Nov 03, 2016 10:18 am
Hi there
I searched the forum for help in my specific problem but didn't find a solution. If there is any post out there which solves my problem I would appreciate your hint.
I would like to do the following: I would like to bind a keyboard key with a modifier to the rotation axis of my SpaceNavigator, lets say Control+ArrowDown to HIDMultiAxis_Rx.
I am able to realize the simple key generation with the follwoing code:
    <Axis>
     <Enabled>true</Enabled>
    <Input>
     <Min>-512</Min>
     <Max>0</Max>
     <Deadband>100</Deadband>
     </Input>
    <Output>
     <RepeatStyle>PressAndHold</RepeatStyle>
     <Reversed>false</Reversed>
    <KeyStroke>
     <Key>51</Key>
     </KeyStroke>
     </Output>
     </Axis>
But when I try to implement the 'Control' Modifier as follows:
    <Axis>
    <Input>
     <Min>-512</Min>
     <Max>0</Max>
     </Input>
    <Output>
    <KeyStroke>
    <Modifiers>
     <Modifier>Control</Modifier>
     </Modifiers>
     <Key>51</Key>
     </KeyStroke>
     </Output>
     </Axis>
...nothing changes to the example above. So I just get the ArrowDown and the modifier is ignored.
Is there any way to bind a Modifier+Key to the axis?
Josh
Re: Binding Modifier+Key to rotation axis
Post by Josh » Fri Nov 04, 2016 10:05 am
I moved my Post to the ordinary Windows forum.
mmaaat
Post by mmaaat » Sun Aug 26, 2018 11:27 am
Have you succeed?
