Integrating Space Navigator with Delta3D
saravanan
Post by saravanan » Mon Aug 17, 2015 4:23 am
We have integrated Delta3D with the Space Navigator using the SDK provided by 3D Connexion. We are facing some issues with handling events from Space Naviagtor and screen refresh (redraw).
The code to handle event is given below
void DispatchLoop()
        MSG msg;
        int handledEvent;
        SiGetEventData EData;
        SiSpwEvent         Event;
        BOOL               getMsg;
        // Process messages
        if ((getMsg = GetMessage(&msg, NULL, 0, 0)) != 0)
        //if (PeekMessage(&msg, NULL, 0, 0, PM_NOREMOVE))
                SpwReturnValue ret;
                handledEvent = FALSE;
                if (devHdl != SI_NO_HANDLE)
                        SiGetEventWinInit(&EData, msg.message, msg.wParam, msg.lParam);
                        if ((ret = SiGetEvent(devHdl, 0, &EData, &Event)) == SI_IS_EVENT)
                                if (Event.type == SI_MOTION_EVENT)
                                        // Handle motion event
                                        SbMotionEvent(&Event);
                                handledEvent = TRUE;
                // If it wasn't a 3D mouse event, handle it through the normal channels.
            if (handledEvent == FALSE)
                        TranslateMessage (&msg);
                        DispatchMessage (&msg);
void Delta3DApp::PreFrame(const double deltaSimTime)
        // Dispatch message loop
        DispatchLoop();
        // Perform 3d model update
When using GetMessage() function i am able to receive Space Navigator events, but the scene will be refreshed only if there is any key/mouse/SpaceNav events. If i use the PeekMessage() fuction, i am not able to receive the Space Navigator events properly, but the screen is refreshing properly. I have tried placing the event receiving function (Dispatch Loop)in an another thread, but that is not working. Kindly provide us a solution.
Thanks.
Re: Integrating Space Navigator with Delta3D
Post by UtaSH » Mon Aug 17, 2015 8:41 am
Moving this to the Developer Forum.
Post by jwick » Tue Aug 18, 2015 6:09 am
Isn't GetMessage blocking? Some event is needed to cause it to return.
