import comtypes.client as client
from ctypes import *
import logging
console = logging.StreamHandler()
console.setLevel(logging.DEBUG)
formatter = logging.Formatter('%(name)-12s: %(levelname)-8s %(message)s')
console.setFormatter(formatter)
logging.getLogger('').addHandler(console)
types = { # What others?
0:"Unknown",
6:"SpaceNavigator",
4:"SpaceExplorer",
25:"SpaceTravler",
29:"SpacePilot"
class POINT(Structure):
"""Point struct used in Win32 api functions."""
_fields_ = [("x", c_long),
("y", c_long)]
class MSG(Structure):
"""Message struct used in Win32 api functions."""
_fields_ = [("hWnd", c_ulong),
("message", c_uint),
("wParam", c_ulong),
("lParam", c_ulong),
("time", c_ulong),
("pt", POINT)]
def PumpWaitingMessages():
"""Windows API function."""
user32 = windll.user32
msg = MSG()
PM_REMOVE = 0x0001
while user32.PeekMessageA(byref(msg), 0, 0, 0, PM_REMOVE):
user32.TranslateMessage(byref(msg))
user32.DispatchMessageA(byref(msg))
def GetMessage():
#BOOL GetMessage(LPMSG lpMsg, HWND hWnd, UINT wMsgFilterMin, UINT wMsgFilterMax);
msg = MSG()
user32.GetMessageW(byref(msg), None, 0, 0)
return msg
def DispatchMessage(msg):
user32.DispatchMessageW(byref(msg))
class KeyListener:
"""Catch and print keyboard events.
Note: some keys either don't send events or give bad key codes.
def __init__(self, keyboard):
self.exit = False
self.keyboard = keyboard
self.exitCode = 1
def cont(self):
return not self.exit
def KeyDown(self, this, code):
print 'Keydown: %s, %s' %(code, self.keyboard.GetKeyName(code))
if code == self.exitCode:
self.exit = True
def KeyUp(self, this, code):
print 'Keyup: %s, %s' %(code, self.keyboard.GetKeyName(code))
class SensorListener:
"""Catch and print sensor events."""
def __init__(self, sensor):
self.sensor = sensor
def SensorInput(self, this, inval=None):
print "Rot: ",
print self.sensor.Rotation.X,
print self.sensor.Rotation.Y,
print self.sensor.Rotation.Z
print "Trans: ",
print self.sensor.Translation.X,
print self.sensor.Translation.Y,
print self.sensor.Translation.Z
# Get device
device = client.CreateObject("TDxInput.Device")
print types[device.Type],
if not device.Connect(): # Returns failed
print ": Connected!"
# Setup keyboard listener
keyboard = device.Keyboard
listener = KeyListener(keyboard)
client.GetEvents(keyboard, listener)
# Setup sensor listener
sensor = device.Sensor
client.GetEvents(sensor, SensorListener(sensor))
# Start event loop
while listener.cont():
msg = GetMessage()
#PumpWaitingMessages()
If you are using pywin32 you should be able to fine the GetMessage, DispatchMessage, and TranslateMessage functions in win32event module.
One continuing problem I've had though is that some key events don't seem to be working correctly. I have the SpaceExplorer - the model with the second most buttons BTW. I'm guessing that the esc, ctrl, etc keys are generating normal keycodes like a keyboard? What are the key codes for 2d and 'fit' though. I think 32 is the keycode for 'fit', but keyboard.GetKeyName(code) raises a undefined COM error?
* This poster neither endorses nor encourages the consumption of alcohol, except in cases involving the Component Object Model or the Window's API*
