Solid Edge Panning in Draft
mpranger
Post by mpranger »
I am currently using the SpaceNavigator mouse:
Release version 3.17.6
Driver version 6.17.6
Firmware Version 4.22
I am also using Solid Edge ST3 on a Windows 7 64bit Professional on a Dell Precision T3600 machine. The computer is new (1 month) but I have been using the SpaceNavigator for a few years.
The new issue I am having:
When I am in draft mode, I very lightly push on the mouse with my thumb trying to make the drawing pan to the left. The drawing wants to go down to the right until I push hard enough on the mouse and it then goes to the left. This behavior is not seen in any other program I use (Adobe Acrobat 10x) and works fine.
I have tried to plug this into another USB port with no luck. I have also updated the drivers to 3.17.6 (was 3.17.4).
This behavior is seen on other Dell T3600 machines, but is not seen on machines that are a little older (Dell Precision T3500)
Any thoughts of what I might be able to try?
Barbara
Re: Solid Edge Panning in Draft
Post by Barbara »
Hello mpranger -
There may be a way to correct the problem you are seeing with the Space Navigator.
Please contact our technical support.
Barbara
