Every time I use the update wizard I am prompted to insert the "3D connexion getting started cd" during program maintenance. How come?
This is getting very annoying so what can I do to avoid inserting the cd every time when using the update wizard?
The thing is I only have a cd with software & user`s manual that come along with my SpacePilot (first version) and no getting started cd........
Update wizard issue......
Hi Victor
Please remove your existing installation of 3DxSoftware, download the new one (v3-1-8 ) and install it. The new version wouldn't ask for the "3Dconnexion getting started CD".
agoenczi
Update
Hi Victor
Remove at first your installed 3DxSoftware completely. That makes sense because an older installation could made some settings which influence your current one.
If you will be absulutely sure, then follow the procedure described in the following post and install only afterwards the new 3DxSoftware v3-1-8.
agoenczi
update......
thanks for the solution.
