TDxUnrealEditor version 5.3 not working with UE5.3.1
kkochiss
Post by kkochiss »
I'm getting my unreal project set up and I can't seem to get the plugin to load. I followed the steps and placed the plugin that ships with version 10.8.16 of the 3DxWare within my Engine/Plugins/Marketplace folder of my source build of UE5.3.1. When loading my project I get an error stating:
Plugin 'TDxUnrealEditor' failed to load because module 'TDxUnrealEditor' could not be initialized successfully after it was loaded.
I stepped through the debugger and it looks like it finds the dll handle but does not find a function for InitializeModule so the it fails to init. Is there anyway to fix this?
Re: TDxUnrealEditor version 5.3 not working with UE5.3.1
You may want to check if updating to UE 5.3.2 resolves this.
If you cannot update to 5.3.2, trying "verifying" the UE installation in the Epic Games Launcher.
kkochiss
Post by kkochiss »
Hello, thanks for the reply. I upgraded my source build from UE5.3.1 to UE5.3.2 from the Epic games git hub and the plugin still fails to load. Do you know if the TDX plugin is not supported on source builds of Unreal Engine? Is there anyway for us to debug this to figure out what the issue is?
driedrat
Post by driedrat »
I'll have a look to see if the same error shows up. Strangely, the spacemouse WORKS, even if the plugin fails to show in the UE5 list of plugins...
