After installing 3dxware 1.5.2 (32 bits) for my SpaceNavigator on Red Hat EL 5.5 (32 bits) it fails to start the driver (see log file below).
I'm starting the driver manually with /etc/3DxWare/daemon/3dxsrv -d usb
Any suggestions?
3DxWareUNIX V1.5.2 ID 5945 log file
Process ID: 3447
Time: 2010-11-12 18:42:54
Machineinfo 1: Systemname=Linux, Nodename=facpp12, Release=2.6.18-194.el5PAE
Machineinfo 2: Version=#1 SMP Tue Mar 16 22:00:21 EDT 2010, Machine=i686
Runlevel-Info: run-level 5 Nov 12 18:42 last=S
[2010-11-12 18:42:54] uddev.c, 1198: UdDevInit() 0x821e008
[2010-11-12 18:42:54] 3dxsrv.c,806: displayname = $DISPLAY set to :0
[2010-11-12 18:42:54] 3dxsrv.c,811: putenv() was successful
[2010-11-12 18:42:54] 3dxsrv.c,813: displayname is now :0
[2010-11-12 18:42:55] 3dxsrv.c :: startupInittab(), authGetUser(), failed to get user
[2010-11-12 18:42:55] Error: 3dxsrv.c :: startupInittab(), authGetUser(), failed to get user
[2010-11-12 18:43:01] auth.c :: authGetUser(), FOUND: user home = "/home/facsim"
[2010-11-12 18:43:01] 3dxsrv.c :: startupInittab(), authGetUser(), user=facsim
[2010-11-12 18:43:01] UdDev: Opening USB device on USB port /proc/bus/usb/002/003
[2010-11-12 18:43:01] Error: Could not open USB port or no supported device found! Exiting!
