I am using Spacemouse with Sketchup 2018. Without changing any of the Axes settings the left/right roll stopped working. The axes settings are still mapped correctly
This happened after I used the 'lock' button - when I unlocked it everything worked apart from left/right roll. I restarted and even reinstalled the driver but with no success
can anyone help?
Spacemouse Enterprise left / right roll stopped working
Re: Spacemouse Enterprise left / right roll stopped working
Hello richardavatar,
I assume that the "Lock Horizon" option is active.
You need to open the Popup menu and then deactivate it. The Popup menu can be launched with one of the buttons. Unfortunately I don't know by heart which one. Either you can see it in the 3Dconnexion properties or you just map the command "Popup menu" to one of the buttons.
