Questions and answers about 3Dconnexion devices on Windows
Postby MarkV » Thu Dec 02, 2010 6:24 pm
My device (SpacePilot Pro) did not appear to be in the .inf. Somewhere in the thread I found a reference to a device ID containing 626 where as my SpacePilot Pro shows 629 (USB\VID_046D&PID_C629&REV_0411&MI_01)
I'm under Win7 x64 using the Zebra mod.
I attempted to use the dgeo to sign the driver and put the OS into test mode, but the Device manager reports the device could not start.
I am a few months behind on this thread, so I'll go back and take a look-see.
MarkV
Postby jr.beronha » Fri Dec 03, 2010 4:17 am
Hi guys, i have a space navigator for notebooks, i'm installing a rcb9 drivers for win7 64 perferct i used a NGOHQ.com's Driver Signature Enforcement.
But, my space navigator not worked. I saw something in other posts about changing the line in .inf file, but did not quite understand.
Could someone help me?
jr.beronha
Re: Working 64-bit version posted
Postby necko77 » Fri Dec 03, 2010 7:42 am
Omniflux wrote:Well, another user finally did what I haven't found time to do and finished updating the RBC9 driver for 64-bit versions of Windows.
You can download it from my website at http://www.omniflux.com/devel/#rbc9
If it works for you, please thank zebra78 for his great work, and if you can't get it to install, blame me for writing the bad INF file.
You should also thank RBC9, but where did he disappear to?
And remember, a vendor solution is coming!
Yes vendor is great LOL
They will probably finish it in 2014 year
So its perfect that we have you, and you did job, 5 years faster them them :)
REspect for all poeple envolved in this little project ! 8)
necko77
necko77
Postby A Future Pilot » Fri Dec 03, 2010 8:58 am
Well I'm very interested in buying a SpaceNavigator...but I'd like to make sure it works on my favorite game before dropping $100 in to it. Is there anybody out there who would be willing to see if it works on DXX-Rebirth for me?
A Future Pilot
Postby A Future Pilot » Fri Dec 03, 2010 9:09 am
One other question...does the zebra mod work on x86? Or should you just use the original for x86 and the mod for x64?
A Future Pilot
Postby zebra78 » Fri Dec 03, 2010 6:52 pm
I have not tried this at all with x86, but the .exe may very well work with it... all I can say is to try it out!
The driver (.sys) will not work in x86, so don't load that or the inf.
zebra78
zebra78
Descent
Postby Jonny Tenebrous » Sat Dec 04, 2010 7:45 am
A Future Pilot wrote:Well I'm very interested in buying a SpaceNavigator...but I'd like to make sure it works on my favorite game before dropping $100 in to it. Is there anybody out there who would be willing to see if it works on DXX-Rebirth for me?
Ah, you read my mind, and I'm already 4 days ahead of ya ;). Yes, I can safely vouch for the fact that the SpaceNavigator is, indeed, the best controller ever for Descent 1 and 2. Did "6 Degrees of Freedom" ever exist as a term before before those games, anyhow? So, while I haven't tried Rebirth exactly, I am using its bigger brother the D2X-XL sourceport with the RBC9 drivers in Windows 7 x64. I've set the SpaceNavigator to control forward, reverse, strafe sideways, and strafe up/down in the left hand while I use a 5-button mouse in the right hand to control pitch up/down, rotate, and the weapons. Sick. The ONLY thing I can imagine would make for the ultimate setup, in my personal opinion, would be adding a set of rudder pedals to the equation... in Descent I'd probably use those for forward/reverse instead of the tilt forward/back axis of the SpaceNavigator (which I've discovered I prefer to the sliding forward/back axis). Still, aside from being almost 15 years late to the game, I'm not really complaining.
Jonny Tenebrous
Postby Phaedron » Sat Dec 04, 2010 11:14 am
I tried DXX-Rebirth today. I bound all axis on my SpaceNavigator to joystick axis X,Y,Z and rX,rY,RZ. I pumped the deadzone in the RBC driver up to 100 for binding the axis to the DXX controls, but turned it down when playing. All axis worked except for rY (look up/down). Somehow it wouldn't recognize it as Joy1-A5. A1-A4 and A6 worked.
This axis works on all (modern) games I tried out, so I expect it to be a problem of DXX. I couln't find a way to edit a conf file to force it, so as far as I know, there isn't a workaround. Perhaps this could be brought to the attention of the developers ?
Phaedron
Postby Phaedron » Sat Dec 04, 2010 11:32 am
BTW, there might still be options to bind keys to the controls used in DXX. However, I prefer having analogue control. In D2X-XL, I couldn't get any of these axes working, probably because they only support the joysticks that were around originally when D2 was released.
Phaedron
Postby Phaedron » Sat Dec 04, 2010 1:51 pm
OK, scratch both of the above posts. Joystick binds ARE possible, for both DXX and D2X-XL, and both work perfectly. The trick is, the rY axis isn't usually configured in 6 axis joysticks, but the Slider axis is.
In the RBC9 tool, bind the axes in the following way:
Top row: X, Y and Z axes
Bottom row: rX, Slider, rZ
Now the axis can be bound in DXX from the config tool:
Pitch U/D: Joy1 A-5
Turn L/R: Joy1-A6
Slide L/R: Joy1 A-1
Slide U/D: Joy1 A-3
Bank: Joy1 A-4
Throttle: Joy1 A-2
In DX2-HD you can bind all axis, but have to do it in the \profiles\default.plx file.
Because axis in the profile start from 0 instead of 1, here's the accompanying config lines:
joystick.Pitch U/D[1].value=4
joystick.Turn L/R[1].value=5
joystick.Slide L/R[1].value=0
joystick.Slide U/D[1].value=2
joystick.Bank L/R[1].value=3
joystick.throttle[1].value=1
Sorry about the previous confusion, but I wasn't really at home with current day Descent port configs and such.
Phaedron
RBC9 Tool - SpaceExplorer - profiles
Postby balieu » Sat Dec 04, 2010 4:10 pm
Hi all
I have been monitoring this thread for some years now, and finally installed the 64bit version of RBC9.
It works with my SpaceExplorer, thanks to all of you, well at least it moves the mouse up and down when I tilt the knob, which I presume is what the default driver is configured to do.
Since I am using the driver with a SpaceExplorer, it seems that I can't change it's profile with the RBC9 tool.
Could you tell me where the default profile is located, and whether it's possible to edit it by hand (is the profile binary) ?
And if not, is the source for the tool available? Since 4 devices are supported, it should be possible to add a 5.
If I have missed some earlier reply, please just say so, and I will move through it all again.
Michael
balieu
Working with the x64 RBC9 Tool
Postby YBW » Tue Dec 14, 2010 10:08 am
Greeting's all,
In the past I used the Office plug-in to let me work in unsupported programs. It didn't do all that I wanted, but it was enough.
Now I'm on a Win7 x64 box and need something outside of SolidWorks. I download the RBC9 Tool from Omni Flux but it doesn't appear to support the SpacePilot Pro. Am I missing something?
If the pro is supported, can someone direct me to instructions for setting up the Tool?
Thanks.
YBW
Postby Phaedron » Tue Dec 14, 2010 1:14 pm
I (tried) to explain the setup steps for the SpaceNavigator in this post
The Spacepilot Pro might have a different ID than USB\VID_046D&PID_C626, but probably still is in the C62x range.
However, it is not included in the inf file. I don't know if you can force the normal SpacePilot drivers to load for it, but if you can't, you might have to hack the .inf file to include the identifier for the pro.
I don't know if that would even work theoretically, but I would give it a try. Try to find out the identifier in the USB devices properties, and add something like the following:
Underneath the line:
%RBC9_TRA.DeviceDesc% =Install, USB\VID_046D&PID_C623 ; SpaceTraveler
something like
%RBC9_PRO.DeviceDesc% =Install, USB\VID_046D&PID_C62X ; SpaceTraveler
(where X is the ID for the SpacePilot Pro)
and underneath line:
RBC9_BAL.DeviceDesc="RBC9 SpaceBall64 MouJoyKey v2"
add
RBC9_PIL.DeviceDesc="RBC9 SpacePilotPro64 MouJoyKey v2"
Then save the inf file, and do all the steps in my post to get it to load the driver.
Phaedron
Postby Phaedron » Tue Dec 14, 2010 1:17 pm
-1 for not not being able to edit posts, should be
something like
%RBC9_PRO.DeviceDesc% =Install, USB\VID_046D&PID_C62X ; SpacePilotPro
(where X makes it a valid ID for the SpacePilot Pro)
add
RBC9_PRO.DeviceDesc="RBC9 SpacePilotPro64 MouJoyKey v2"
Drop me a PM if it doesn't work, we might be able to work it out using other comms.
Phaedron
PreviousNext
Return to Windows Discussion Forum
Who is online
Users browsing this forum: No registered users and 5 guests
