Ubuntu 9.04 mad scrolling
Questions and answers about 3Dconnexion devices on UNIX/Linux
Postby eyeJ » Mon Jul 13, 2009 2:42 pm
Hi I have a problem with 3dxware.
When I press a shortcut to switch between desktops to the one containing Maya 2009 menus and gui items across the screen start madly scroling. for example Alt + Left. The only way to stop it is to kill 3dxware.
Any ideas?
eyeJ
Re: Ubuntu 9.04 mad scrolling
Postby UtaSH » Tue Jul 14, 2009 3:18 am
Hi eyeJ,
is the shortcut mapped to one of the buttons of the device or do you just launch it with the keyboard?
Do you see any difference at the CPU?
Which driver version do you have and which device do you use?
Uta Ludwig
Postby eyeJ » Tue Jul 14, 2009 7:25 am
Shortcut is mapped to the keyboard it happens when I do some operations in maya. For example when I press the enter key in the channel box (using the keyboard) 3dconnexion driver keeps madly pressing the enter key until i kill it.
I also experience slowdowns when I use smooth proxy and move the mouse across the screen while moving with the space pilot. If I don't move the mouse across the screen while navigating I get like 250 fps in poly proxy but when I just move the mouse across the screen and navigate I get serious viewport lag less than 1/3 fps.
Driver version is 1.4.0, Space Pilot firmware version V4.04
I checked the cpu when this enter key issue happens there is no significant change in cpu usage.
Hope this info gets you a better idea what the problem is :)
eyeJ
Postby UtaSH » Thu Jul 16, 2009 1:37 am
Hmm ... this is really weird.
Are you using a 3d desktop or another tool on top of the window manager? This might influence the flow of the messages of the XServer.
Postby eyeJ » Thu Jul 16, 2009 11:11 pm
No I have:
Section "Extensions"
Option "Composite" "Disable"
EndSection
in xorg.conf so there is no extra 3d desktop effects enabled
eyeJ
Postby UtaSH » Fri Jul 17, 2009 1:14 am
Can you check if the issue with the Enter key happens with another program, too? For example the xvalue that comes with the driver.
When you launch that from the command line there will be output for every keypress. When you press the enter key in the xvalue demo there should be two lines (one for pressing the key and the other for the release) like this:
    - keysym=ff0d0 z= +0 a= +0 b= +0 c= +0
Do you get the same or more that the two lines?
Postby eyeJ » Fri Jul 17, 2009 10:17 am
I get standard two lines also the problem doesn't happen when I switch desktops with xvalue. I guess it must be a problem with maya plugin then or something related to xinput in ubuntu.
I've set the SpacePilot not to be used as xinput device recently because I tried it with the open source driver for SpaceNavigator so it might have fixed the problem for 3dxware to. I'l test it more with maya and report back my findings :)
eyeJ
It was the keyboar causing trouble
Postby eyeJ » Thu Aug 06, 2009 6:47 am
I think I fixed the problem but I'll have to test it some more to be absolutely sure. Seems that the last time I cleaned my keyboard I misaligned something inside and because of that keyboard was causing the trouble.
Now pressing the enter key on the letter part of the keyboard while changing values in the channel box doesn't make Maya go mad... so far so good...
I will report back when I'm sure the problem is fixed. :D
eyeJ
Return to UNIX and Linux Discussion Forum
Who is online
