So - i had it working perfectly earlier.
but now - The connection between my SpaceNav/Cadmouse and the 3dXware is gone.
i can set the settings.
Apps don't see the 3dXware settings?
Behaves as if the settings are default - as if the 3dXware wasn't installed at all?
make sense?
Tried to re-install
help please !
3d Connexion loses connection to Apps ?
Re: 3d Connexion loses connection to Apps ?
Hello ethanr,
which apps are you using with the SpaceNavigator and the CadMouse?
Can you see the devices in the preference pane in the system prefs?
Which driver version do you have installed?
Hi -
the main app I am trying to use is VectorWorks.
I'm on 10.4
At one point it was working great - then I tried to import settings that someone sent me - and it stopped working.
It seems to e working in other applications
Somehow its connection to VectorWorks is what has snapped
help please
Thank you
I'm on 10.4
help please
Thank you
Hi ethenr,
we have published a new driver version last week - 3DxWare 10.4.5. Please download it here. Let me know if that solves your issue. Thanks.
No - the VectorWorks application (my main use) still does not recognize any of the settings.
I even have tried changing the "Any Application" setting.
I am not sure what you mean with "the Any Application setting".
Try if removing the existing configuration solves the issue. See here how to do that.
