C# / C Sharp Example
Re: C# / C Sharp Example
I sent you the links.
Zoony
Post by Zoony »
I can build csMonitor to an exe with Visual Studio 2010 and run it on my Win7 64bit system no problem and my SpaceMouse Wirelss is read correctly, BUT . . .
I need it to run as a DLL for a plugin with my host application. I created a new project with a new form that has only one textbox and this loads okay from my application menu.
The problem is I get this error;
System.InvalidCastException: Unable to cast object of type 'TDxInput.Device' to type 'TDx.TDxInput.DeviceClass'.
And the culprit is the line indicated below that you should recognise from the csMonitor example; ( so it works if target is exe but not if dll )
private TDx.TDxInput.Sensor sensor;
private TDx.TDxInput.Keyboard keyboard;
private TDx.TDxInput.Device device;
private System.DateTime lastUpdate;
private bool isRunning;
public Form1()
InitializeComponent();
isRunning = false;
try
this.device = new TDx.TDxInput.Device(); // ****************** this line causes the problem
this.sensor = this.device.Sensor;
this.keyboard = this.device.Keyboard;
this.lastUpdate = System.DateTime.Now;
. . . etc.
Why ? and more importantly, what is the answer ?
Zoony
Post by Zoony »
4 Days and no reply ?
LeifB
Post by LeifB »
Hey folks,
The examples from UtaSH are great but they reply on WPF. If you're using plain C# and Windows Forms (like me), here's a little trick to make it easy to hook up to your Windows Forms code as a message handler and so on. It's a helper class as follows. (You could also in theory extend their class, but they marked it as "sealed").
    class Mouse3DHelper : IMessageFilter
        public _3DxMouse._3DxMouse my3DxMouse { get; private set; }         // This is the class from the examples
        public int NumberOf3DxMice { get; private set; }
        public Mouse3DHelper(IntPtr Handle)
            // Connect to Raw Input & find devices
            my3DxMouse = new _3DxMouse._3DxMouse(Handle);
            NumberOf3DxMice = my3DxMouse.EnumerateDevices();
            if (NumberOf3DxMice > 0)
                // Capture Window events
                Application.AddMessageFilter(this);
        public bool PreFilterMessage(ref Message m)
            if (my3DxMouse != null)
                my3DxMouse.ProcessMessage(m);
            return false;
You can then use it as follows, i.e. in your Form constructor:
            Mouse3DHelper helper = new Mouse3DHelper(this.Handle);
            helper.my3DxMouse.ButtonEvent += my3DxMouse_ButtonEvent;
            helper.my3DxMouse.MotionEvent += my3DxMouse_MotionEvent;
Where the event handlers are as previously defined (see examples). And that's it!
Enjoy!
mijo
Post by mijo »
I'd like to get the C# sample as well
mbonk
Post by mbonk »
Zoony wrote:I can build csMonitor to an exe with Visual Studio 2010 and run it on my Win7 64bit system no problem and my SpaceMouse Wirelss is read correctly, BUT . . .
Can you post a full sample project which displays this behavior, please.
Markus
mijo wrote:I'd like to get the C# sample as well
Links sent in a PM.
C.Müller
Post by C.Müller »
I'd also like to have the C# exsample. :)
Links sent in PM.
alex77
Post by alex77 »
I'd like to get the C# sample as well.
I cannot to access ftp :(
EmilyC
Post by EmilyC »
Hi, I'd like to have the C# example too please.
Links sent to both of you. :)
EmilyC
Post by EmilyC »
Thank you very much!
Phranky
Post by Phranky »
can you please send me the C# sample code too.
Thanks!
Hi Phranky,
Sample source code is no longer available from the FTP server. Please contact 3Dconnexion'sAPI Support and they will assist with your request.
Locked
