Using SpaceNavigator with GIMP
Questions and answers about 3Dconnexion devices on UNIX/Linux
Postby ettore » Mon Mar 03, 2008 1:17 pm
GIMP on Linux has a nice input controller module that can be configured to use our devices. Let's see how we can enable it and work around a few problems we'll encounter. I'll keep this post as short as possible and post more explanations later.
1. Download the ndof_input.sh script from here, copy it inside /lib/udev/ and make sure it has execution rights:
chmod a+x /lib/udev/ndof_input.sh
You will need root priviledges for this.
2. Add (as root) the following line to /etc/udev/rules.d/10-local.rules or create file if it doesn't exist:
KERNEL=="event*", IMPORT{program}="ndof_input.sh %p", NAME="input/%k", GROUP="ndofusers", MODE="0644"
3. Terminate the 3Dconnexion driver if you have it running. Unfortunately GIMP is not compatible with our driver and the two interfere with each other.
4. Disconnect and reconnect our device if you had it plugged in.
5. Open GIMP --> Prefs --> Input Controllers. Add the "Linux Input" entry to the panel on the right. Double-click on it to configure it.
6. Open the "Device" drop-down list, you should see your 3Dconnexion device. (If you don't, repeat step 4.) Select the device. The "State" label should update to something like "Reading from /dev/input/eventN"
7. Now we can map the actions to the events. This is kind of up to you, but anyway these are my favorites:
Event "Button 0" Action: "tools-paintbrush"
Event "Button 1" Action: "tools-airbrush"
Event "X Move Left" Action: "view-scroll-left"
Event "X Move Right" Action: "view-scroll-right"
Event "Y Move Forward" Action: "view-scroll-up"
Event "Y Move Back" Action: "view-scroll-down"
Event "Z Axis Turn Left" Action: "tools-paint-brush-scale-decrease"
Event "Z Axis Turn Right" Action: "tools-paint-brush-scale-increase"
8. Click OK and close all panels.
You now should be able to pan the image L/R/U/D if it's zoomed in, select your favorite tools with the SpaceNavigator buttons, and increase/decrease the brush sizes by twisting the knob left/right. A cool thing is that you can change the brush size and paint at the same time. Feel free to play around with the other actions, GIMP is fully configurable.
One problem with this solution is that the sensitivity and speed is not adjustable. I hope it's helpful anyway. Feel free to report any issues or improvements.
ettore pasquini
software engineer
3Dconnexion, inc.
ettore
Postby ettore » Mon Mar 03, 2008 1:33 pm
A few in-depth notes on the above post.
- Regarding point 1 : the intent of the script is to detect NDOF devices only. This should include our devices and analog joysticks, but it should leave out keyboards, 2D mice, and other devices. To verify how devices are added, type
$ ls -la /dev/input/event*
crw-r--r-- 1 root ndofusers 13, 65 2008-02-29 11:06 /dev/input/event1
You should see lines like the above only for your joysticks and 3D mice.
- Regarding point 2 : As it's written in the previous post, the rule adds the device with "read" permissions for everybody. This is fine for most users. However, if you're concerned about security in a multi-user workstation, the group "ndofusers" is something you could use to restrict access to NDOF devices to only users belonging to that group. Of course you'll need to add the users to the group if you want to do that:
# groupadd ndofusers
# adduser ettore ndofusers
Change the local-rules entry to a more restrictive:
KERNEL=="event*", IMPORT{program}="ndof_input.sh %p", NAME="input/%k", GROUP="ndofusers", MODE="0640"
Now only users who belong to the "ndofusers" group will be able to use NDOF deviceswith GIMP.
ettore pasquini
software engineer
3Dconnexion, inc.
ettore
Postby Absum » Tue Mar 04, 2008 5:32 am
awesome :D
Absum
Postby Absum » Wed Mar 05, 2008 5:28 pm
typo in the url btw
should be:
http://cubelogic.org/downloads/ndof_input.sh
Absum
Postby ettore » Wed Mar 05, 2008 5:35 pm
Absum wrote:typo in the url btw
thanks -- fixed!
ettore pasquini
software engineer
3Dconnexion, inc.
ettore
Postby abeowitz » Thu May 15, 2008 6:36 pm
Thanks! This is useful!
Can't adjust sensitivity as mentioned, but it works!
abeowitz
Gimp
Postby abeowitz » Thu May 15, 2008 6:57 pm
OK, question.
Is 'sensitivity' controlled by the number of events? in other words, this script is called with EACH event then?
abeowitz
Postby simoncion » Sat Jul 26, 2008 1:32 pm
As I read it, no.
The linked script has nothing to do with processing events generated by the SpaceNavigator. The script is run by udev, the Linux device manager. The line that you add to 10-local.rules says "for each 'event' device, run this helper script. If it returns A-OK, then make this device owned by 'ndofusers'".
Anyway, It seems to me as if GIMP is not taking into account the *magnitude* of the axis movement, so you seem to only get one speed of adjustment... *WAY* too fast for small images and *WAY* too slow for huge images. *sigh* I wonder what it would take to make GIMP consider the magnitude...
simoncion
Postby GPD » Tue Feb 10, 2009 3:32 pm
found it more useful to
put scroll up/down left/right to both translation and rotation to this direction, so I have a choice of two "speeds" because it receives two events.
Also, put scroll in/out to the buttons.
Helps, but still it is not what it should.
We should be able:
- to zoom in and out with the controller (not working usefully)
- translate page left right with speed control
GPD
Postby ideas_arte » Sun Nov 01, 2009 12:56 pm
I have GIMP 2.6.7 running on Mac OSX 10.6.1, any idea how to apply this?
:wink:
I have a SpaceNavigator SE, and this is the version of drivers:
if a solution will be very happy and grateful.
Greetings from Central America :D
ideas_arte
Postby ideas_arte » Sun Nov 01, 2009 1:00 pm
sorry for talking about mac on linux, but need help
:oops:
ideas_arte
Postby bmeagle » Sat Sep 11, 2010 12:18 pm
Hi all
Got a space navigator and I'm trying to get beyond the paper weight spinning cube stage.
When running ndof_input.sh I get the following error:
./ndof_input.sh: line 23: 0x03: command not found
./ndof_input.sh: line 24: 0x04: command not found
./ndof_input.sh: line 25: 0x00: command not found
./ndof_input.sh: line 33: 0x16: command not found
./ndof_input.sh: line 41: /syscapabilities/ev: No such file or directory
./ndof_input.sh: line 42: /syscapabilities/rel: No such file or directory
I am running gentoo linux, any ideas?
Regards
bmeagle
Re: Using SpaceNavigator with GIMP
Postby arkanoid » Mon Sep 03, 2012 1:07 am
What about serial Spaceballs?
arkanoid
Postby someoneee » Mon Oct 01, 2012 2:00 pm
Nice tut.Thanks for sharing!
someoneee
Return to UNIX and Linux Discussion Forum
Who is online
cron
