3DXWare values language
Questions and answers about 3Dconnexion devices on Windows
Postby mlutz » Mon Nov 05, 2007 7:19 am
Sounds I got some issue with the 3DXware and Catia V5
My Catia install is using English Language.
3Dxware Control Panel starts with French. I was able to change the Menu Language into English, but the value for the button conf are still in French.
So finally when I want to use a function like "Centrer Tout" (Center All), catia Tell me that it is an unknown Command
How can I fix that
B.R.
Mathieu
mlutz
Postby Peter » Mon Nov 05, 2007 10:45 am
Mathieu,
I am not certain what driver version that you are using. We may be able to resolve the problem by reinstalling the 3dx driver (if you have not already done so).
You can download the latest 3dx driver from: www.3dconnexion.com
When you install the driver, be sure to select ENGLISH for the language to be installed.
Peter
Peter
Postby mlutz » Tue Nov 06, 2007 12:09 am
You're right --- I already did it (took the last dirver + install with the English Language)
The application starts in English but value for the button conf are still in French (which is my windows language, I do not now if this is linked)
mlutz
Postby rstadie » Tue Nov 06, 2007 1:11 am
Hello Mathieu,
you can try the following:
Important: Incorrectly editing the registry may severely damage your system. Only follow the procedure below if you are confident that you understand the instructions. Always make a backup of the registry before editing and make sure that you understand how to restore the registry if a problem occurs!
1) Open your registry editor
2) Navigate to HKEY_LOCAL_MACHINE\Software\3Dconnexion\3DxWare or, if only applicable to the logged in user, HKEY_CURRENT_USER\SOFTWARE\3Dconnexion\3DxWare.
3) Create a new value (as string) named "CATIALocale" (without the quotes)
4) Set the value data to: 1033
5) Restart the driver
Please let us know if this worked for you.
Robert Stadie
rstadie
Postby mlutz » Tue Nov 06, 2007 1:51 am
No change ... values are still in French
mlutz
Postby mlutz » Tue Nov 06, 2007 2:18 am
adding it in HKEY_LOCAL_MACHINE\Software\3Dconnexion\3DxWare
->You were faster than me (I was just testing that ...)
Now it works
Thx for your help
Mathieu
mlutz
Postby mlutz » Tue Nov 06, 2007 2:20 am
For Got My previous message.
I wanted to say that :
HKEY_CURRENT_USER\SOFTWARE\3Dconnexion\3DxWare. it doesn't work
under :
HKEY_LOCAL_MACHINE\Software\3Dconnexion\3DxWare : it works fine
Mathieu
mlutz
Postby ngomes » Tue Nov 06, 2007 11:42 am
Hi mlutz,
Are you positive about that? The software is meant to work with both sections of the Registry.
Return to Windows Discussion Forum
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
