[AutoCAD 2007] bug with Selection Preview Effect
Questions and answers about 3Dconnexion devices on Windows
Postby wvbesien » Mon Mar 19, 2007 5:35 pm
AutoCAD 2007 has a "Selection Preview Effect": lines get thicker when you go over them with the mouse pointer.
Bug:
(1) make a block
(2) move mouse pointer over block: lines become thicker
(3) navigate with SpaceNavigator while mouse is over block
(4) stop navigating
(5) move mouse away from block
(6) bug: lines are still thick, until you select the block and press escape.
Release version 3.1.8
Driver version 6.1.7
Firmware version 3.17
Edit: It's not only with blocks, also with simple lines,...
wvbesien
Postby agoenczi » Tue Mar 20, 2007 5:35 am
Hi wvbesien
I tried to reproduce the scenario you described. I didn't succeed.
I moved the mouse over a block, the block got thicker lines, I started to navigate and I removed the mouse - the lines still remained thick until I finished the navigation.
I have used AutoCAD 2007 with a SpaceNavigator.
Could you specify more details in order to reproduce this issue?
agoenczi
agoenczi
User
User
Postby wvbesien » Sun Mar 25, 2007 10:38 am
Can you try again in 2D Wireframe mode?
I get this when the mouse is over an object:
before navigating (2D Wireframe): lines get thick
during navigation (automatic switch to 3D Wireframe): lines become thin (!)
after navigation (switches back to 2D Wireframe): lines are thick again
after removing the mouse: lines are still thick (!)
wvbesien
Postby wvbesien » Thu Apr 19, 2007 11:21 am
Isn't it possible to reproduce this bug?
wvbesien
Postby agoenczi » Thu Apr 19, 2007 11:46 pm
Hi wvbesien
I will try to reproduce this bug again with a 2D wireframe model and I will let you know about the result.
agoenczi
agoenczi
User
User
Postby agoenczi » Fri Apr 20, 2007 6:21 am
Hi wvbesien
I tried again and I could reproduce the issue.
The lines aren't reverted after the navigation as they were before the navigation. I only used a polyline defined as block and inserted several times.
I used the classical AutoCAD interface and the latest 3DxSoftware v3-2-2.
agoenczi
agoenczi
User
User
Postby agoenczi » Fri Apr 20, 2007 6:36 am
Hi wvbesien
I recorded this issue in our bug-tracking system under the number 4436 (for your reference).
agoenczi
agoenczi
User
User
Postby wvbesien » Sun Apr 22, 2007 1:31 pm
OK, thank you!
wvbesien
Return to Windows Discussion Forum
Who is online
Users browsing this forum: Bing [Bot], Exabot [Bot] and 4 guests
