jwick wrote:nicolight wrote:ok
Do you have any ideas about problems I got with the Beta12? What did you mean with "Turn on the log file and attach it to your reply."?
I don't even know what you were running. There are no French error messages in 3DxWare 10, so I'm thinking you were always working with 3.15.5. Clean up your machine, with the help of our helpdesk, and try it again.
Jwick I know I made mistake writting my posts, yes I used the 3.5.15 version when I got error message "impossible d'ouvrir une interface utilisateur". I know its not directly the subject but it could help the others. When you install beta version and then decide to install the original driver, you will rich this message. And the only solution is to make a clean uninstall but.... Just one information, when you are going to delete 3Dconnection folder and spwini.dll and iappdll.dll : use windows search. There is others that are not indicate in the process here:
http://www.3dconnexion.com/nc/service/f ... d%5D=cleanFor me it was the solution. Hope it will help you.
About 3DxWare 10.
First pics, you will see my downloads, the one I used is grey. we can choose the language... but we have to choose english, right?
- installation.png (29.66 KiB) Viewed 5698 times
Anyway, you told me that beta versions are only in english I chose english but I got the same error message. I decided to answear "yes". As I could see last time, it doesn't install everything (like driver folder).
Better than uninstall it, I decided to install again. So the software proposed to me "remove","repair" and something else. I choose "repair".
And surprise, it worked!!! It's completly mysterious...
