I'm a student from Italy,
Just yesterday I've got at university an old SpaceBall 4000 FLX (serial, not USB).
My intention was to use it to move (as manual jog device) a numeric control milling machine.
We use the free software EMC2 ( www.linuxcnc.org) to control our machines.
This software includes HAL (Hardware Abstraction Layer) that is a thing like LabView where you have (and can create) several modules with input/output pins and connects them.
Just yesterday, using this HAL, I succeeded in moving my CNC machine using an inexpensive USB joypad. I used a module called hal_joystick that creates a virtual pin (float type) for every axis and (bit type) for every button.
Now the question is: is it possible to read the SpaceBall axis position so that i can create a pin reporting it, just like the module hal_joystick does?
I've installed the 3dxware driver, and tried the xvalue demo. It shows all axes values...if only I could read them with a script or a C module the problem would be solved.
Or is there a standard way to interact with the 3dxware driver in order to retrieve the axis values?
Many thanks,
Manfredi Leto
