Sisync functions
Sisync functions
Postby phildel » Thu Dec 02, 2010 6:38 am
I want to use the sisync... functions (with siappdll.dll) and I always have the same result : SI_SYNC_WRONG_HASHCODE
For information all non sisync... functions work well
Does anybody have any ideas about this problem?
Thanks in advance.
Philippe
phildel
Postby jwick » Thu Dec 02, 2010 7:38 am
The hashcode is calculated by the siapp library when you get a sync request from the driver. You can't sync until you get one of these. To get one, you have to have APPLICATION_CONTROLS_BUTTONS = true in your application's .scg file (which means you need to make an scg file for your application).
Once you get a sync request event, you should be able to call the SiSync functions using that SiHdl.
Postby phildel » Thu Dec 02, 2010 8:15 am
Thanks for the replies.
Do you have an example to use this functionality?
Thanks in advance.
Philippe
phildel
Postby phildel » Thu Dec 02, 2010 8:35 am
It works, I received the sync request and after I can use the sync functions, but I need to force the selection of my configuration file in the control panel. How can I force the use of the configuration file when application start?
Thanks in advance.
Regards
phildel
Postby jwick » Thu Dec 02, 2010 11:04 am
Does your application have a window? It's window getting focus is the only way to get the driver to switch to it.
Postby phildel » Fri Dec 03, 2010 12:35 am
Yes my application has a Window.
I founded a solution, I added a SiSyncSendQuery after SiOpen and I receive the sync request, but the needed configuration must be active, is it possible by code to choose and activate a configuration among those existing?
Thanks in advance.
Philippe
phildel
Postby jwick » Fri Dec 03, 2010 7:38 am
No there is no way via the sync api to choose a specific scg file. The scg that is used is saved in the registry. Before you start mucking around in the registry though, the new driver doesn't use the registry, so anything you do now will be broken when 3DxWare 7 is released.
Make sure your scg file has the correct executable name. You'll have to edit it with notepad. Make sure it isn't using "*.*". Then you need to switch to it once in the GUI. The relationship of that exe to scg will be saved in the registry and it should be used next time you start your app.
Postby phildel » Tue Dec 07, 2010 2:10 am
It does work, however I don't think it advisable to let clients be able to carry out this operation, it seems more appropriate that this should be transparent for the user and should not need his intervention.
Thank you for your help.
Philippe
phildel
Return to Developer's Forum for Windows
Who is online
