I am using WM_INPUT / RawInput to get information from
3Dx SpaceNavigator in Win32 application (Delphi).
Using this method bypasses the 3DxWare driver. I need to calibrate the SpaceNavigator bypassing the 3DxWare driver. Who can help ?
What we recommend is that you "scale" the data to [0..1] if input is [0..350]. Your code, after scaling the raw data, should allow for values of higher than 1. This can happen if the user increases the sensitivity of the device (higher "tick" count for same applied force/torque).matilla wrote:However, there is one thing I don't understand using rawinput. This is the value of the limit for each direction. It's different depending on the axis but always close to 350.
Could I know these values?
Return to Developer's Forum for Windows
Users browsing this forum: No registered users and 3 guests
