I tried loading the 5.3 driver but it's not working. It wont even load unreal now saying the TDxUnrealEditor failed to be found.
I created the marketplace and 3dconnexion folder as per prior instructions. I also changed the engine version in the TDxUnrealEditor.uplugin but it was a nogo.
Changing "EnabledByDefault": false, at least allows unreal to load.
Running 3dxware version 10.8.19.3708 (currently up to date)
unreal engine 5.4 support
Re: unreal engine 5.4 support
Hello jlo,jlo wrote: ↑Sat Mar 23, 2024 3:02 am I tried loading the 5.3 driver but it's not working. It wont even load unreal now saying the TDxUnrealEditor failed to be found.
We do not have support for 5.4 yet. You also tried the same work around I would have tried but it seems it will not work. WE are working on another driver and it should support for 5.4
Can you give us an estimate for when the driver will be available?
Thank you!
Thank you!
We have had support available for UE 5.4 available since quite some time but it was available to those enrolled in the Insiders programme.
The plug-in for UE 5.4 is available from the Unreal Engine Marketplace (web page here). It was published today, April 24.
Useful knowledge. Please share other suggested links?
