hello,
i am quite new to linux and absolutely new to spacepilot.
installed spacepilot usb under ubuntu 6.10.
downloaded actual driver version 1-1-1 and installed it.
got first problem:
error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
googled, installed 'libmotif3' => package. this problem solved.
second problem is:
it seems to me, that the driver is NOT loaded automatically after reboot
when entering manually (as root)
/etc/3DxWare/daemon/3dxsrv -d usb
the blue light starts lightning.
third problem is:
when trying to execute ./xcube the message
"No driver is running. Exit ..."
is displayed.
looks like the problem described in another thread here.
but at me, the blue window does only pop up for a very very short
time (closing immediately) - it is nearly unreadable, so fast it closes
the window.
when repeating this command for sometimes i believe it is the wanted
application.
but why does it close the window immediately after opening it ?
i know, there is no support for ubuntu but i hope, there will be
any hints ...
some more informations:
- lsusb does display the spacepilot id and name.
i believe this is correct.
- when doing a "ls /proc/bus/input/devices -la" only
"-r--r--r-- 1 root root 0 2007-01-23 20:41 /proc/bus/input/devices"
is displayed.
here i don't have enough knowledge whether this is ok or not.
would appreciate any ideas and hints.
many regards
stefan
