SpaceExplorer in AutoCAD2006?
pgannon18
Post by pgannon18 »
My SE doesn't work in AutoCAD2006. Is there some problem, or is the new driver only good for 2007?
znissan
User
User
Post by znissan »
Hello:
Please go to our driver download section of www.3dconnexion.com. After you select your product, select "Archives" and you'll find a plug-in for AutoCAD pre-2007 versions. You can use that with a SpaceExplorer.
Ziva Nissan
3Dconnexion, Inc.
pgannon18
Post by pgannon18 »
So is it just a plug-in, not affecting the driver I have installed, or will it replace what I have running now? I don't necessarily want to use an older driver, but it would be nice to be able to use it within AutoCAD 2006.
znissan
User
User
Post by znissan »
It is a plug-in specific to the support of earlier versions of AutoCAD. The plug-in which ships with 3DxSoftware supports 2007 and later.
Ziva Nissan
3Dconnexion, Inc.
pgannon18
Post by pgannon18 »
Thanks for your help.
rschader
Re: SpaceExplorer in AutoCAD2006?
Post by rschader »
Is this plugin for Autocad 2006 still available anywhere? I cannot find it under the archives at this time!
